1987 OMC SeaDrive 1.6L Mount Swap?
kbrill
I'm pretty new to boating and brand new to the forums here. I've searched and have found some allusion to what I'm trying to do, but looking for more specifics. With that being said, I've recently inherited a 21' proline with a '87 OMC seadrive 1.6L 140hp motor that has been sitting for several years. The shaft assembly is shot. They seem tough to find and very expensive. My question: Is there a newer (and more affordable?) mount I can use instead of replacing the existing shaft? The rest of the mount is in working shape, but still not great so I'd like to attempt a full swap if it's manageable rather than replace things one at a time every time I take it out.
southkogs
kbrill I've moved you to the outboard section - that sea drive is an outboard, not an I/O I believe. Let's see if someone over here knows your answer.
Auxlarry
What shaft assembly are you talking about? The sea drive uses a pretty much standard power head with the exception of a few extra linkage mount hokes in the block.
Auxlarry
If yoiu want to remove the sea drive engine mount you will have some transom repair work to do before mounting a jack plate or other mount to the boat. The sea drive has two large holes through the transom, one for the fuel/oil/cable and wiring block and one below that, about a 6" diameter hole for the trim motor that protrudes through the transom...those will both have to be filled in properly.
