dbernstein7
Thread starter- Joined
- Apr 17, 2019
- 5
Hi! So I just bought a 1987 bayliner with a 1987 85hp Mercury Force outboard engine. It starts right up and sounds good in idle. When I push the throttle into gear, the prop starts to spin, but when I push the throttle down, the engine sounds the same as it does in idle, and the prop moves at the same speed. This happens when the throttle is completely opened up. I wasn't using the right size Muff so I don't know if enough water was going into the intake. Could this be the problem? Anything helps. Thanks!
