1987 Mercury 150
FISHINJUNKIE
What should compression be on all 6 cylinders? I done a compression test on this engine today cause i am thinking about buying the boat this engine is on. When i done the test on all 6 cylinders gauge reading was 93psi per cyinder.Is this normal? Thanks
Faztbullet
Re: 1987 Mercury 150
Try a different guage as that is low(95psi)...
FISHINJUNKIE
Gauge is brand new OEM,i am new to boat engines i've been told if all cylinders are close in Psi should be ok motor.Could have been i did compression test wrong and getting a false reading? If compression is that low what does that tell about engine?
j_martin
Like bullet says, try another gauge. It's about 25 lbs low.
