UNSUREBOATGUY
- Sep 14, 2009
- 117
1987 Mercruiser 3.0 with alpha 1. Weird noise that I can't seem to figure out. I'm no boat or engine expert so please go easy on me. It usually only appears between about 1400 rpm and 2500-2800 rpm. It usually goes away at idle, though it didn't for this video for some reason. The engine wasn't quite warmed up all the way-maybe that had something to do with it?
Doesn't seem to matter if the engine is under load or not. I really noticed it mainly on muffs in the driveway because I do not usually spend much time in this rpm range on the water. (I don't rev it up that high on muffs either, but as I let it warm up around 1200 rpm, sometimes it would creep up a little and start making the noise-that is how I first noticed the noise.) I don't ever notice it accelerating-not sure if it is because of the engine working hard or not.
I replaced the exhaust shutter, thinking maybe that was the noise. Didn't make a difference. I cleaned and lubed the dizzy weights to be sure it wasn't caused by sticking advance. They move really nice now, but no difference in performance. I do not have a timing light, but the engine seems to run pretty much perfect, so I figured it was correct. I can certainly get a light and check timing if that would be helpful.
http://www.youtube.com/watch?v=1JMjMg0uto8
Please let me know what you think. Thanks a bunch.
