ok guys heres the problem, about two weeks ago i could not get the engine running, thought it was a bad fuel pump, so i cleaned the filter that goes in the carb inlet, poured a little gas down the carb and she fired up, now prior (about 2-3 weeks) it ran great, nice and smooth. now it has a little sputter at idle. i set the dwell on the points to 30 degrees, gapped the plugs to 35, set the timing 6 degrees btdc, and the miss is still there, i changed the cap, rotor, points, plugs, fuel water sep. about 1.5 months ago, anything im missing here, the only thing i did not play with was the carb. it was rebuilt last year. its got one mixture jet on its side, how many turns out should that be?
