1987 Johnson Primer Solenoid
shipwreck63
I started the engine a few days ago, then serviced the water pump....now when i try to start it the normal click one hear when the key/ignition is pushed in.....I do not hear. upon a closer inspection I came across this red valve handle attached to a part labels 397909(Primer solenoid)....well with putting the small screw onto the shift arm I think I might have moved it. Motor does not start now....I don't think it is getting fuel not hearing any type of combustion going on.
Are other options than replacement of solenoid?
:confused:
ezeke
Re: 1987 Johnson Primer Solenoid
The red handle on the primer solenoid should be aligned with the cylindrical base.
