1987 johnson gt 150
zapad
I have a 1987 johnson gt 150 engine that smokes bad and carbs leak gas out of front comp 89 on 4 cyl 90 on 2 rebuilt carbs disconected vro checked timing runs good but smokes bad new plugs and wires mix is 50 to 1 syn oil could not find leaks anywhere help am lost
flyingscott
First thing is use punctuation.Do the carbs leak all the time? 2 strks do smoke it can be normal. Revisit your carb work if they leak all the time and make sure the floats and needles are in good shape.
