1987 Johnson 88HP not starting, power pack?
yackyack
Did a carb rebuild and changed plugs. Got it to run but it was real rough, had to hold the throttle open a little to keep it going. Found bad coil, changed that and new plug wires. Now it won't start at all. Used a timing light and found the starboard cylinders aren't firing. Did a ohms check on the power pack and it seems good, but I'm not sure I did it correctly. I don't want to by a power pack and find out it's something else. Any clues on what to do.
