elfelt
Thread starter- Joined
- Mar 7, 2017
- 6
Ok, this is post #1 for me! I need some major help!
I have a 1987 55hp Johnson commercial that was running rough and bogging down at the end of last year. It is an intermittent problem that doesn't seem to be effected by temp, runtime, or anything else really... but when it runs well (60% of the time) it runs great!
Symptoms:
Idles great! revs in neutral, but as soon as it is under load it will not increase in rpms and goes very slow. (5mph) I can run it on the muffs and it sounds great! revs in neutral, reverse and forward...
It trolls rough if at all, reverse or forward doesn't make a difference.
I have good spark on both cylinders while cranking (haven't checked while running under load)
carbs look clean but I have not taken apart yet
gas tank may need replacing, its an old metal tank with a new hose and fittings, but it works fine on other outboards sooo...
Primer ball stays "hard-ish" with problem is happening and choking the motor has no effect on rpm when the problem is going on, BUT when the motor is running well a full choke will kill it.
I noticed a pretty high amount of black oily gunk coating the outside of the shaft of the motor, from the base of the powerhead do to the lower unit...and there are some globs of blue/black sticky (a little firmer than grease) in the housing of the motor.
My best guess: bad reed valves...
The gasket for the air-box shroud (not sure if that's the name) had a tear, so I'm thinking that maybe if I have bad reed valves there is unburnt fuel coming back through the air box and leaking into the motor housing, causing it to leak down the shaft.
Thoughts?
Symptoms:
Thoughts?
