Alright This is what it is so far. I have Replaced all fuel lines, Rebuilt/Cleaned Carb 2x, Rebuilt Fuel pump, Installed Inline Fuel Filter and I cannot seem to get it to Idle. Compression is Even, Good Spark on Both Plugs. I Have racked my brain with this for awhile and cannot seem to figure it out! The motor Starts and Runs with the throttle advance lever up however when you put the lever down for normal idle/operation it dies Immediately when cold and will run for a few minutes when warm and then sputter and die. Good gas in the tank.... Motor Bogs down when sprayed with carb cleaner while running... I'm at a loss Im not sure what else to try. I have adjusted and readjusted the "low speed Needle" to no avail.... Any suggestions?
