1987 Johnson 28hp died starved for gas seems
Flatlander02138
Seems the outboard has often run rough and petered out going slow or idle. Sometimes even goin full tilt it will cough and die. Then pushing in the key enough and lifting the warm up lever I can get it going again. Though it was fuel pump leak or clog? So ordered that. Also thought maybe carb is clogged. Tried spraying cleaner in and had it going a bit now nothing. Wanna pull carb. But DO I NEED to pull off starter etc first? Also how do I know if it's fuel pump or seperate electric solenoid fuel primer thingy?
jakedaawg
K. Stop spraying. Are cleaner into a running engine. It will eventually destroy it. Don't use starting fluid either.
If by squeezing bulb while running it still quits the fuel pump is not the issue.
On older
Outboards we always start
With a compression test and an open air gap
Spark test and a fuel
Sample into a clear jar. Report
Back those findings.
Yes, you have too remove the starter to pull the carb. A parts blowup helps find the tricky to locate fasteners
Honorary Supreme Mariner
The fuel primer " thingy " is only used for starting the motor.---A new diaphragm for the fuel pump is available and cheap.-----Do a compression test as a first step in trouble shooting.
