1987 Johnson 150hp
Dylan_short
Hello, I recently just purchased a 1987 chapparal. I'm new to owning a boat. Motor is a 87' 150hp 2 stroke. It starts right up and runs like a top. Occasionally when I go to take off and go into full throttle it falls on its face and most of the time dies. If it doesn't die, I can throw it in neutral and rev it up and it will take off just fine no problems. Any ideas on what the problem could be? Hopefully that all makes sense. Like I said I'm new to owning a boat and don't know all the proper terms lol. Thanks a bunch.
Dylan_short
Timer base was working like it should. Replaced plugs , primer ball, fuel filter tonight. Have went through fuel lines looking for cracks or somewhere air could be sucking in and all the lines looked good. Gonna take it out in the next couple days and see what happens. Thank you boobie for the reply.
cfauvel
whew that could be a host of things wrong....
I don't think fuel pump, as you go like a banshee after the symptom appears and you rev it up...
is this model a plastic carb-ed model? if so could be dirt in the idle/intermediate air bleeds, or gunk in the brass tubes going into the fuel bowls.
my gut says it is an intermittent ignition problem...like boobie suggested a stuck timer base will give that symptom..
a bad stator would give that symptom, but when it does that it typically doesn't allow you to get pass 2500rpm so you being able to go at speed, ALMOST rules that out.
a going bad powerpack or coil would do that too.
Do you have any diagnostic tools like multimeter, DVA adapter, and jumper wires? and a that year/model service manual from OMC?
go to CDI electronics for the parts and for some ignition trouble shooting techniques.
flyingscott
I do not believe you have plastic carbs as your motor should be a crossflow motor. Have you done a compression test? Have you checked your link and sync? You should get a model specific manual. What is your idle speed in gear? I would also look at your carbs.
