1987 Johnson 150 VRO
goldtop
I have a 1987 Johnson 150 VRO. The motor is white, the lower unit is blue, I'm guessing it's evinrude. Running down the lake, the prop stopped spinning and the motor over-revved. Now when it's in gear the prop spins freely with a slight noise at the top of the lower unit. I tried to take off the lower unit, loosened 5 bolts and it wouldn't budge. Can someone help me please? Any suggestions would be appreciated.
Mettaree
Re: 1987 Johnson 150 VRO
goldtop: Did you rempve the bolt that is hidden under the adjustable trim fin under the anticav. plate? It's up in a cavity under there. You may have snapped your driveshaft.<br /><br />Fair Skys
D
DJ
Guest
You also have to disconnect the shift linkage. It is under the bottom carburetor. It's easier if the gear shift lever is in reverse.
Brew
Not sure about the Johnson 150, but the easiest way to get at the shift linkage on my 140 Evinrude was to take 5 minutes and remove the lower cowling from the motor. <br /><br />Spent the 20 minutes prior to that scraping my knuckles and cussing at the thing.<br /><br />Good Luck.<br /><br />Brew
ob
Sounds like a parted or stripped driveshaft.Make double certain that we're not chasing a spun prop problem.
goldtop
Thank you all for your help, but it seems to be a job for a man with more patience than I have. I'm going to wait for my buddy to finish up with the car he's working on and let him have a go at it. Thanks again.
