Occassionally we have been running down the lake near WOT and have had the boat feel like it hit something. It isn't hitting anything...but loosing power for just a single moment. The last two times we were out the motor would only go to about half throttle speed and would shake more than normal. I would reduce the throttle and run it back up, same thing. If I reduce the throttle just under the halfway (around there) the shaking would go away and it would run pretty smoothly.
I have always been able to run WOT or near a bit later...never been stuck out in the middle of the lake yet... Seems something is beginning to fail and might be the power pack?
I recently changed the Fuel Pump because of an unrelated issue. I do not believe it to be fuel related..carbs, lines, bulb etc. Nor is it the prop. Does anyone have any thoughts and DIY checks I can do? I'm pretty handy and plan to do any work myself. Thanks!
