1987 Johnson 110 WOT RPM?
Vinnie
Hi Guys, I just bought an 87 Senza 165 with a 110 Johnson on it. Kick *** boat btw. Right now at WOT it is reving at about 6200 RPM which seems a bit high to me. What is the max WOT RPM for this engine?
Thanks, Vin.
kenmyfam
Re: 1987 Johnson 110 WOT RPM?
Double check it with another tach before making any decisions. I the meantime keep it down a little till you know for sure. I don't know the official WOT range on that motor . I am guessing at 5,000 to 6,000
tashasdaddy
5500 is top, 4500-5500 hp rated at 5000.
Vinnie
Thanks guys for your responses!
5800 seems to be the sweet spot for these motors even though 5500 is the recommended WOT RPM. 6200 is twisting it a little tight.
Vinnie
So what size prop should I use? I have two that came with the boat. I'll try to read the numbers off them. The one is a larger diameter but they both reved about the same.
Dhadley
Look at your tach first. Make sure it's an OMC or BRP tach and it's set on position 6.
