Clayton Sikes
Thread starter- Joined
- Apr 1, 2002
- 1
My Bayliner boat has a "quick disconnect" type setup between the bulb and the fuel pump/filter assembly. This setup seems to greatly impede the flow of fuel from the bulb to the fuel pump. The motor stumbles/bogs down at full throttle but ONLY at full throttle. When I removed the quick disconnect setup I temporarily placed a piece of rubber fuel line from the bulb to the fuel filter/pump but when I began to squeeze the bulb fuel began to overflow from the top carb. Does the quick disconnect "thingy" also serve as a sort of flow regulator?<br /><br />Thanks, Clay
