1987 force 50 hp impeller cover weep hole
richie c
Should the impeller cover have the weep hole ? What is the water comming out of the weep hole for?
Frank Acampora
Re: 1987 force 50 hp impeller cover weep hole
Yes, there should be a small weep hole about 1/32 inch in the top of the pump case. I am not sure of the reason but I suspect it has to do with either faster priming of the pump or equalizing water flow through the pump when the thermostat is closed. Could even be to keep excess pressure off the seal. Anyone else out there know for sure?
WillyBWright
It's to let the bubble out when the pump is immersed.
richie c
Thanks Guys for The Info, Thanks Again
