Re: 1987 Evinrude XP200 - major tune up (??)
Ok... three items... pulse valve, in-line fuel filter, and fuel pump.
Second first... with engine running, should the fuel filter be 'full'..?? or half full..?? When pumping the primer bulb the fuel filter gets about half full. When engine is started, the filter is basically 'empty'. I can see gas in it, but very little. Nothing changes when throttle is run up... very little 'observable' fuel going through the filter. Considering how much fuel these beasts consume, it doesn't appear to be much gas going in. Can't say I ever 'noticed' how it appeared before...
Pulse Valve... where IS this thing..?? It doesn't appear to be on the pump itself... can't seem to 'see' it on the crank case..
If it turns out the fuel pump is not working correctly, I've already got info on a pump 'kit', but since I'm using premix, and don't intend to run the VRO, is there a 'replacement' strategy that uses a different fuel pump..??
The oil line at the fuel pump, from the reservoir, is disconnected and 'plugged'. It appears that a low oil/low fuel flow alarm switch is disconnected as well.
Any thoughts..??
