- Apr 10, 2020
- 15
Well, got my fuel pump installed and now have a fuel leak from somewhere. I have taken the carbs off, fuel pump off again, traced the fuel lines, etc. I can’t figure out where the devil the leak is. I can pump the bubble up and it gets stiff but then looses pressure. The motor will run just for a short bit then die. It’s like pulling teeth to get it to start again. That’s when I found out it’s loosing pressure somewhere. I had my son pump it so I could try to find the leak then fuel just starts pouring out from some unknown place. It was running down the outside of the lower unit. I thought it was leaking behind the top carb but nope. Any ideas of where else to find the leak?
thanks!!
thanks!!
