Tim Kane
Thread starter- Joined
- Nov 28, 2010
- 18
I have a Evinrude 70 hp motor E70ELCUR, and it stalls after a couple seconds when first shifting into forward, or reverse. This is my first season with this boat so it's new to me and when I bought it the guy told me it did not like to idle. The gas is fresh. Filters are new. A quick increase of throttle keeps it going and it will run all day an any speed except for idle. I tried messing with the idle adjust screw but it seems like this was not the answer. Made for shifting at too high of a speed. So if shift into forward and give it more throttle right away, it's fine but as you can imagine, this makes docking very difficult if not dangerous, with constant stalling starting. I removed all three carbs and cleaned them. Inspected them for any cracks or anything that was different, they all looked very clean. I cleaned them again and re-installed. No change. I made a very small butterfly valve position adjustment on the top carb (on the linkage that connects all three) and that increased idle speed a bit but did not cure the stalling issue. I don't know what else I can adjust. Can anyone help me out with this problem? I appreciate any help. I have spent hours on this and I am about to give up.
