DeepSpaceSailor
Thread starter- Joined
- Aug 13, 2020
- 13
Hello everyone!
This forum helped me a lot in the past with this outboard, so, here's another situation:
I assembled this outboard that I found in pieces in a junkyard. It had everything, I assembled it with no problems but those already resolved with the help of this forum. Now the engine won't start. Starter motor is perfect, it does its job. It spins the flywheel and thus, the crankshaft, but it seems no fuel is getting to the cylinders. If I manually open the carburetors flaps and using a syringe spray fuel inside, it starts. But once that fuel is consumed it stops. Spark plugs are working, there's spark in all cylinders. I took the carburetors out and cleaned them again and made sure everything was cleaned and with no obstructions. Disassembled fuel pump to make sure everything is ok and it was. Fuel pump is working.
Sorry for my english. I'm not a native speaker. If you need more info, ask for it and it will be given.
Thanks to all of you for this awesome community!
