1987 E150STLCUR couple problems
yello
Morning guys, I been having a few problems with my Evinrude 150XP. The first problem i noticed is a small stream of gas coming out of the top of the bottom carb. More like a spitting effect not a stream. I took the airbox off but I cant seem to figure out where its coming from exactly. My 2nd problem is sometimes when i shift into forward, there is a strong vibration / clunking through the whole boat until it gets on plane. I tried adjusting the shift cable today in garage but wont know for sure if it went away until i take it back out. As soon as it gets on plane though the vibration goes away. And if i come off plane and go again its fine. It just seems like the initial start up after its been setting for a little while.
yello
Is it normal for there to be some play in the part that moves the shift rod id assume? like maybe 2inches sides to side play. Also I noticed my shift cable seems to kind of bind when running in forward or reverse. Theres a slight movement it seemed like.
