1987 Crusader 270....ignition situation
Knightime
I have an 87 Silverton with twin 270 Crusaders.
The port side (L.H.) engine is misfiring. In checking the spark plug wiring I found the them to be connected opposite of what I believe they should be.
Starting with #1 the wiring order is connected counter-clockwise.
The rotor turns clockwise, thus the wiring order should be connected clockwise....correct?
Assuming I am correct, (the wiring order should go clockwise with the rotation of the rotor)....how is the motor running?
(it does run, rough and does not come up to power under a load)
I have my suspicions but, would like to hear your thoughts?
Ayuh,.... It fires in the direction the rotor turns,...
Switch the wires 'round, 'n try it,....
Lyle29464
I think what might be heading you in the wrong direction is the firing order. Unless you have a V drive the port engine turns the same as a car. So the firing order is the same as a car and most likely is on the intake manifold. To get the firing order for the starboard side just move #1 to the end and read back words. The port S/B 18436572 the starboard just move the 1 to the end and read it backwards 12756348
