JFLORES12000
Thread starter- Joined
- Jun 6, 2009
- 4
ok i have basic electrical skills but i'm stumped.engines are 454's. port side will not crank,the y/r wire to starter solenoid has no power when turning key, but if you put a test light to it and turn the key it starts just fine.also put test light at neutal saftey switch and i starts fine. checked neutral saftey for resistance and got zero ohms(good).i lossened and retightened the starter bolts no change. i dont get it why when i use a test light grounded to the block to check for power on y/r wire while cranking does it crank normal.PLEASE HELP ME UNDERSTAND
