1987 90hp Johnson V4 weak pee stream
Croix_boy
Attached is a video of my motor running today. It is a 1987 90hp V4 with an outboard jet Lower unit. Lately it has had a weaker stream so I assumed it was a bad impeller so I just replaced the entire impeller, housing, seals, etc. it does not get much better then this even when I add rpms. Any help or guidance is appreciated as to what to look for next.
boobie
Have you ran a wire up the tell tale tube to see if it's clogged up ??
ondarvr
Did you clean out the pee tube, they clog up frequently.
fireman57
If that is not clogged then you will want to take out the tstat and check those passages. After that it is removing the exhaust side and cleaning the water paths in there and new gaskets.
Fed
I'd put the little plastic jet thing on it to make it more like a water pistol than an open hose.
As it is you are going from a smaller hole at the block into the larger discharge hose so it will always be a dribble.
Croix_boy
It was left open for the hope that it would pass more stuff as it gets ran in shallow water. In the past is had a much stronger stream with the same set up. I went to pull the elbow indicator at the block as the tube was free of any blockage. I accidentally broke the elbow indicator taking it off but when I did pull it out it did seem to be clogged fairly good and took a bit if prodding with a hanger and water under the faucet to get it flowing water cleanly. I will pick one up tomorrow and take it to the lake to see if that was my issue. Crossing my fingers. Thank you for all the quick responses.
