1987 90hp Evinrude hot terminal
mine
have a 1987 90hp evinrude and no manual - I want to confirm battery cable landing points - please see diagram - is positive terminal cable to land as indicated on solenoid? and negative on starter? thanks in advance rs-90 hp diagram.jpg
Grub54891
Looks ok to me. Did you just acquire this motor or are you having any issues with it?
mine
yes new used to me - and getting it ready for the water - and i noticed the positive post was hot on start - so checking wires and cable - checking voltage drop -
Grub54891
More than likely just a corroded/loose connection. It may look ok but it should be taken off and cleaned up,tightend down. If it's bad enough,replace the cable end or wire itself. Even a low/bad battery can cause things to heat up,as its trying to grab more amps than it can put out.
Also make sure the ground is good and clean.
The negative battery cable is usually bolted to the engine block.
