1987 88hp sp lower unit removal
okprofit
Help,
I think my water pump is bad, I am trying to remove the lower unit. I can not get the shift linkage disconnected. Help!! Is there a trick I am missing?
Thanks for your help
Stuck!!
D
DJ
Guest
Re: 1987 88hp sp lower unit removal
The shift linkage disconnect is under the bottom carburetor. It's easier to see and access if the engine is in reverse gear.
tashasdaddy
remove air silencer, makes it easier to see.
