logcruiser
Thread starter- Joined
- Apr 27, 2009
- 5
My 115 seems to be worn out and looks like all the cylinders would need to be bored and new pistons needed. I have an 88 SPL that has aluminum in cylinder from piston but all others just need honed.
Can I rebuild the 88 block (much cheeper 1 piston 1 boring vs all 4 on the 115) and use the heads and carbs and bubble back from the 115 to have the same HP?
Not using VRO so would the block mounted 88 fuel pump be enough?
Will this work? If so I can run the 115 till it goes......
Thanks,
Mike
Thanks,
Mike
