1987 85HP Force water temp gauge wont work
bungee49
my temp gauge isnt working,replaced thermostat,thermo switch,new gauge,i dont know what problem is.Any suggestions?thanks for any help.
pnwboat
What's the lowest temperature that your gauge will read?
Normal running temperature for the motor with a thermostat is 130 - 140 degrees. Most automotive type gauges start at 120 degrees. The needle will barely move when the motor gets up to operating temperature. I have a gauge that starts at 60 degrees and goes up to 210 degrees. When the motor warms up the needle sits about mid-way on the gauge so it's easy to see.
bungee49
mine starts at a 100 to 250 in black numbers then it goes 40-60-80,in blue numbers,where can i find one that starts at 60,cause i haven't seen one yet,thank you for the info,ill keep trying.
Frank Acampora
Do you have a separate line for the gauge and the overheat? You can not use the same orange wire for both.
bungee49
i dont have an overheat buzzer hooked up,i went from motor to ignition,then gauge to orange on ignition,hope i said that right.
NYBo
There's your problem. The overheat sensor in the head is essentially a heat-sensitive on/off switch. You can't use it to drive a gauge. You need a proper sending unit mounted tot he motor.
bungee49
is that the thermoswitch your talkin about?if so,then i need to put a heat buzzer on and forget the gauge,sorry if i sound ignorant on this,but im not quite sure what i need to do now,if you can explain more,thank you for replying.
MickLovin
Master Chief Petty Officer
If you want your gauge to work you need the appropriate sender to replace the thermo switch, if you just need an over heat buzzer you just need a 12 volt buzzer or original buzzer if you can find one.
NYBo
The overheat sensor does not have direct contact with the cooling water. You could use the threaded hole in the thermostat housing to rig up a water temp sensor.
bungee49
ok guys,i appreciate it,ill figure it out,but this does surely help.
bungee49
do they still make a sensor for a 1987 85hp force? or am i going to have to RIG something up?
pnwboat
There is a threaded pipe plug located just above the thermostat housing on the block. It's a 1/8" NPT threaded hole. You need a sending unit matched to your gauge that has a 1/8 NPT thread. Many of the gauges have a matching sending unit that is 1/8 NPT but you need to confirm that before purchasing.
Also you need to confirm the size of the hole in your dash. If you have an existing hole, it's either 2 5/8 or 2 1/16 inches in diameter.
bungee49
thanks,ill work on it,appreciate the info.
