marky mark
Thread starter- Joined
- Jul 6, 2008
- 3
hi am working on 1987 85 hp force ,the top end is all new ,i changed the complete water pump system in the lower unit ,when the boat gets on plane i can go about 3 to 4 hundred yards then the buzzer goes off an the water coming out the back is really hot ,then u let it sit for about 5 minutes ,then start it up an go the same thing happens ,i took off the bleeder screw at the top of the motor an started it there is alot of water there ,could there be a problem with the thermas stat ,or could the timing be off making it run hot ,an if so how can i check it .Cause this motor is driving me crazy ,so if anyone has any info that would be great thank u for your time
