Model cj8rcud
Cleaned and replaced float valve assembly. Carb was pretty clean but for blob of oil around the needle. When at full throttle it will bog down back off a little and it picks up. Sounds like it is running rich but it only has idle adjustment no fast speed adjustment. I'm mixing 50:1 could this be the result of the blob of oil on the needle, maybe mix 75:1?
