I have a rebuilt 1987 60 HP, did a full lync and sync and it runs perfectly with the cover off but chokes on acceleration when the cover is installed. Also have a small amount of water spitting from the Power head lower gasket. I did do an impeller replacement as well so the lower unit has been off. Could this be the Exhaust tube misaligned or not seated properly, water pump not seated properly? I get a good flow from the tell tale. Any ideas on what might be causing this, much appreciated.
