1987 60 hp Evinrude vs 1984 70 hp Johnson
Force 120
Hello,
I am going to pick up 1987 60 hp with power tilt that has one bad piston (3 cylinders). I want to move the power head of my 1984 70 hp Johnson (non power tilt) to it. The block looks like the same. Please advice if any issues I may have.
Curious to know if the block the same what make 10 hp different?
One motor is rated at the powerhead and one is rated at the prop !
Force 120
So both of the powerheads are the same design or share most of common parts.
How about the carb? Could It be the same carb?
juno pierrat
not same carbs, slightly different styles, i like the 87's. i like chris carson reeds with stuffers,
Force 120
So I think I should rebuild 60 hp power head and replace 70 hp on the boat. Do I expect to lose the speed?
The powerheads are the same HP !!-----One is rated 60 HP at the prop.-----Well it might be 62 .5 but they have to pick a nice number for marketing.
