deerhunt799
Thread starter- Joined
- Nov 2, 2007
- 2
First time poster here.
I had a problem last weekend with my motor. Turned out to be a bad coil. I changed the bad coil and it ran great for about 30 minutes. While the motor was at about full throttle, it cut out. It would only hold a rough idle after that. After messing with it for a few, I found out that it would idle and run fine by disconnecting one of the coil wires. Long story short, it would run on each coil independently (one cylinder), but the second I connected the second coil wire, it would start running rough again. So, I know each coil is functioning.
I'm guessing it could be one (or more) of three things. The power pack, stater (sp?), or the trigger. Does anyone have any suggestions on how I could test this so I don't buy anything that isn't necessary?
Thanks in advance for all your help.
