1987 35HP Mercury Motor/ Not charging battery
taxidermist144
I put my boat in the shop to have it worked on and when I got it back it was in worst shape than when I put it in the shop. It was not running right. When I got it back the inline fuse was blown and a wire that run from the ground bolt on the starter to a part that looked like a selinoid or something was blistered from the wire getting hot. I worked on my motor and got it running fine But now it will not charge the battery. What could be wrong and how do I check the wiring to detemine what part is bad? OH by the way I will not carry it back to that marine shop! If interested the name of the shop in Anglers Marine on hwy 17 in Supply, NC
Barnacle_Bill
Re: 1987 35HP Mercury Motor/ Not charging battery
Test your rectifier. From what you have said it is probably blown.
