Hi all
Have been using this site since I bought my first boat 12 months ago. I bought a 30 year old 14 ft runabout and 25 hp quite cheap for my daughter and I. It does what we need in our local impoundments.
I recently changed the water pump and of course I accidentally lifted the drive shaft. Nothing moved and I put it straight back in. Now I need to move the prop a bit to engage a gear. Everything I have read says shaft out = rebuild. I am really hoping that this isn't true in this case as nothing moved and I only pulled it up an inch as I was sliding the old water pump off. I suspect though that the need to move the prop to engage gears suggests otherwise. Anyone out there advise whether I am pulling it apart again?
Thanks
Aaron
Thanks
Aaron
