1987 225hp johnson
seabird
recently purchased 1987 225hp VRO johnson twin outboards. Was wandering if anyone knew of these particular year outboards having any trouble of any kind. I think I may investigate on disconecting the vro units because I heard there not reliable. thanks for any insight you may have on these outboards.
12Footer
Re: 1987 225hp johnson
I've heard the samew thing. It was a major cause of premature engine failure. I never owned one, but if I did, I'd go back to the old fashoned mixing method.<br />Otherwise, my brother's keeps blowing boxes.<br />He just keeps a spare on board,in the event it happens underway. It gets expensive when it does at 80bukz a pop.Some last years,some last 15minutes, identical manufacturer/supplier. Admittedly, there may be an underlying cause for premature module failure,that he hasn't quite nailed-down yet.<br /><br />They are actually great motors,but would have been far greater if the engineers were allowed to finish it.<br /><br /><br /><br /><br />------------------<br />Time to change my tagline
Dhadley
Good motors. If you have any doubts about the oil injection then disconnect them. Otherwise upgrade to the newer oil pumps that are a constant 50:1. <br />The only other thing I would look at is the flywheel magnets. Reglue all 6 on each flywheel if they haven't been already.<br />Set them up to turn 5800 to 6000 with an average laod, feed them fresh 87 octane with good oil, use Champion plugs and they will live forever. <br />Good luck!
