Blake0912
Thread starter- Joined
- Oct 31, 2010
- 313
I have a 1987 225 johnson that just started having warning horn issues. When im running over 4k RPM the horn will start to sound like its going to go off then stop, basically when the boat bounces the horn will make a sound but not full blast kinda like a screech, but if I back off the throttle it will stop. I checked the temp of the engine with a temp gun and its not over heating. So my thoughts are it has a fuel restriction, but why wont the horn blow full blast if there is a fuel restriction? I can still get 5500 RPM out of the motor. It almost seems like there is a short or something causing the horn to malfunction.
I did ground my brown temp sensor wire to the block with my key in the "on" posistion and the horn sounded off loud and clear.
Also I have recently replaced the fuel pump, fuel filter, fuel water seperator , new fuel lines, new primer bulb. I have not checked the anti-siphon valve on the tank yet or checked to make sure the tank vent line is not clogged. My plan was to hook the motor up to a 6 gal aux tank and run it to see if the problem will go away, meaning I have an issue with my fuel tank.
Anybody have any ideas what else could be causing this problem?
thank you
thank you
