1987 225 johnson outboard loading up at idle.
2010fishinfever
I got a 25' hydra sport with a 225 on the back. It gets up to speed and cruises no problem but when i idle around it starts to load up. I have 150 gallon tank. Is it ok to put the oil in the tank followed by the proper amount of gas? Is de carb ok? where do i get it? what kind? thanks for any help. also small amount of oil coming from top of mid section or bottom of motor any ideas? just changed impeller did i mess the seal on upper exaust gasket? thanks
SparkieBoat
Re: 1987 225 johnson outboard loading up at idle.
yes premix is fine, after you are sure the carbs and lines are full of premixed fuel then disconnect oil lines and plug them, then disconnect vro wires. Yes do de-carb..see secret files at top of this forum. I am not sure about the oil deal..but you do want to make sure everything lines up properly when reinstalling your foot, it takes 2 people to do it properly.
