I have a Evinrude 225hp (1987) on a 21' starcraft, last year was getting about 55mph at 5750 rpm, always been hard to start (tempermental). This year once i finally get it started and out of the marina, i punch it and cant get over 2800, sometimes i am able to get it to plane after a mile or so, once it does I can only get about 4000 rpm. Also around the same time as this problem it will not idle below 1500 rpm for more than 5-10 sec then sneezes when cold and boges down when hot then dies. The sneese seems to be coming from the exhaust not back through the carbs. The problem seems to be getting worse. 1 Power pack, 2 coils, plugs, fuel filter changed and carbs cleaned. compression is #1-98, #2-95, #3-97, #4-83, #5-98, #6-96. Same prop as last year, had about 1/2 tank of fuel from last year topped it off with preminum this year (shop that winterized it doesnt know if they put stabilizer in it).
