1987? 1973 15hp johnson drive shafts interchangeable?
junichi
Hi I am hoping to take the driveshaft out the 1973 ish 20hp pictured and put it in the more modern 15hp long shaft motor in order to shorten it to a 15" leg. Does anyone know if the driveshafts of these motors are the same? Neither motor has a vin or other identification in it so years are best guesses.
Vic.S
I dont think anything prior to 1983 will fit a 1987 model
But why not check the part numbers on the BRP parts website
The parts numbers on boats dot net will link to lists of years and models which any part will fit ....... thats useful
kodibass
Master Chief Petty Officer
no it won't fit, the 20 will fit the 18 HP, not interchangeable with the 9.9 / 15 HP models , as far as I know the flat on the 20 that the impeller fits on will not be the same and overall size is different. jmo.
