cwrigley18
Thread starter- Joined
- Apr 13, 2016
- 1
okay so I got this bass boat off a good trade and im fixing it up and the only thing I have left to fix is this tilt and trim. its a 1987 Johnson 150hp v6 and I replaced a lot of o rings and got it sealed. now I cannot get my tilt piston to go up on its own. I got it as level as I could and filled it level. my 2 trim pistons work good but even they still struggle to move the motor upwards. the electric motor sounds find and when I try to manual lift the engine I can feel some great resistance. im thinking is a bleeding air problem and idk how to bleed it. I left it in the up position overnight after topping it off but it did nothing. now when I have the motor in the up position I can push the up button on the tilt all I want but as soon as I press down the trim pistons start to move in. is it a valve problem with my motor or do you think its still a bleeding problem.
thanks,
v/r
thanks,
v/r
