This may have been an issue before I acquired this motor. I have rebuilt the carbs, side chamber type, with new kits after a thorough cleaning as I usually do. The upper and middle carbs are working ok but the lower carb shoots fuel out of the vent and carb throat when the primer bulb is used and whilst the engine is running. Of course the motor will not get up under load. I have gone over the carb again, replaced the float with two others and replaced the new needle with another. Blowing through the fuel in connector and applying very light pressure on the needle lever mechanism shows a good seal at the needle. The needle levers are set to the Manual specs as are the other two carbs. I have checked that the seat is correctly fitted.
Any thoughts on this would be greatly appreciated.
Thanks.
Thanks.
