whalerfreak22
Thread starter- Joined
- Jul 16, 2008
- 76
Hello all I just bought a 110 powerhead.I did a compression check when I got it and it has 60 psi in each cyl.I popped the heads off seeing that it had been rebuilt with .30 pistons.the bottom right piston has 3 small dings like a piece of foriegn metal got in there.they are near where the exhaust exits the block.I also shook all the pistons to see if there was any slop in the engine and 2 pistons were 'loose' ,like they'd knock if you started it.what do you guys think should I rebuild it again or decarb it?
