1986 yamaha 150
BROOKCAR
I am rebuilding all 3 carbs on my 150 yamaha 86 model and need help adjusting them after i reinstall them back on the motor.<br /><br /> thanks
BROOKCAR
Re: 1986 yamaha 150
WITH THE ADJUSTING SCREWS. SUCH AS HOW MANY TURNS TO BACK THEM OUT.
BROOKCAR
Re: 1986 yamaha 150
When i prime the bubble gas runs out of the carbs, so im sure they need rebuilding, but setting the adjusting screws is what im not sure about.<br /><br /><br /> thanks
topdogeye
Re: 1986 yamaha 150
recently purchased a yamaha 150 proV 1986 timing seems to be off. I havn't put it in the water yet is adjusting the timing simple or should I get a manual?
Basicly it's misfiring at above idle. At idle it seems to pur once I rais up the lever it misfires. I did change the spark plugs not a change in performance though.
99yam40
Re: 1986 yamaha 150
You need to start your own thread.
You may be describing a lean sneeze, hook up a timing light to see what timing is. You may need a manual to see what timing is suppose to be and if it is mechanical or electronic controlled.
may need carb cleaning
