I have an 305 OMC 1986. points were replaced with solid state ignitor kit. This ran great for a season. Now I have low voltage measured at the coil, (.9-3.5 volts). Alternator puts out a strong 16 volts. Coil is new. An engineer friend suggested that my dwell my be off, rotor shaft in distributer worn out, or both. The engine runs fine out of the water. In water under load it bogs down heavly after a few minutes of operation. This problem duplicated with old points system reinstalled. Thanks for any advice!
