1986 mercury xr2 blackmax 150 no spark
Arky86
I lost spark on both banks at the same time. Had an alarm with key on not cranking then wouldn’t start. Pulled it home at that point no alarm, but wouldn’t start. Found no spark on all 6 cylinders. Have a service manual I found an ohm test in it but not a vac. Ohms failed ordered a stator it was an aftermarket but it bench tested the exact same I put it on anyways and still no spark. I disconnected the kill switch, I tested the trigger. I disconnected the jumper wire from the cdi box and I visually examined the flywheel. I also took all the spark plugs out to make sure the motor was cranking fast enough. Anything I’m missing? Junky aftermarket stator? I find it hard to believe that both cdi boxes failed at the same time possible yea but not likely I can’t find the exact tests I need for my components to narrow it down all help is appreciated.
