1986 mercruiser transom plate bolt hole size?
lime4x4
Installing a new transom in boat. What size drill bit do i need to drill thru the transom for the mounting bolts for the transom plate?
Don S
Re: 1986 mercruiser transom plate bolt hole size?
9/16 or 5/8" are typical. The MUST be perpendicular to the transom surface.
zbnutcase
1/2 in will work too and easier to find. 'nutcase
Ayuh,... 1/2" is Fine, it's the size of the studs though, Which means No wiggle room...
jaxnjil
lime when i changed my transom assembly this summer, i used 5/8". they were plenty snug when i put it on.
