1986 Mercruiser 170 4 cylinder
Status
Not open for further replies.
Packers4ever
Just wondering if anyone had any thoughts on this motor...Good or bad...thanks for any help.
rndcomp
Re: 1986 Mercruiser 170 4 cylinder
You don't want my opinion right now, mine might be dead in the water. What I can say is that they are very sensitive to overheating.... Trust me, I learned the hard way!
JoChek219
these 470's are a whole nother beast....... wish I never bought mine
rndcomp
I am starting to think that I am going to use mine as a means to learn more about engines. I am determined to figure out what is wrong with mine, even if I have to pull the whole damn thing apart to find out.
Packers4ever, if you are thinking about getting a used boat with a 470, I can give you a couple of things to look for (although they may be standard across some of the i/o's)
wcsparky05
i've got an '89 140 hp merc 4 cyl that runs like a champ and have been told that its one of the best motors ever built. runs all weekend on a full tank and does 37mph. enough about mine though! remember to replace your thermostat cause they get stuck. you could overheat and cause a lot more damage than a $5 thermostat!
Packers4ever
Thanks for the replys guys, so these motors are called 470's?
Overall I am getting the vibe that no one is a big fan huh?
This engine has a "closed cooling system" (antifreeze with a heat exchanger) This is the first boat I have run with that type of cooling system...any advice?
plassiter1
read on my threads about mine.
when they work, they work great.
I have a 1985 mercruiser 170. closed cooling symtem has its ups and downs, mostly ups. alot easier to winterize.
andy1canada
Howdy!
I owned one for a year or so and never did get it in the water.
The '470-Merc' is likely the most powerful (pound per pound) sterndrive ever built. It was the only Merc-built sterndrive engine block (aluminum) with a Ford '460' iron head planted on it. They came in both 2-barrel and 4-barrel carbed versions.
Some, after learning about and addressing the known issues with this engine, have had great success with these engines.
You need to do the following if you are going to buy one and put it into service:
- don't pay too much for it.
- make certain it still has good compression.
- be certain water is not contaminating the engine oil.
- replace the stock stator/regulator fiasco with a standard one/wire alternator (there are kits available or you can make one)
- these engines came with either a 3-inch or a 4-inch diameter heat-exchanger; you want the 4-inch to eliminate over-heating issues.
- keep an eye on the camshaft/waterpump seals
(read this: http://www.sterndrives.com/470information/470coolantleakrepair.html)
- keep an eye on ebay for spare parts.
- join the forum at Breezeworks.com there's a ton of '470' owners on there who can help you get the most out of these engines.
There are other upgrades you can do to these engines incl. - Petronix ignition, port & polish head, add Scorpion roller-rockers, too name a few.
I've read that some guy's have squeezed over 225-horses out of these things.
Not bad for a little mill that weighs-in about 300-pounds less than a small block.
Hope this helps.
Cheers,
Terry
Packers4ever
Thanks Terry...I really appriaciate the info!!
Status
