1986 Johnson GT 150 flywheel magnets
bobec
I have three loose magnets. What problem will this cause. And what do I use to glue them back on ?
bobec
Re: 1986 Johnson GT 150 flywheel magnets
thanks for the help!
wilde1j
A proper epoxy after cleaning to bight metal. BTW, calm down, nobody gets paid here.
mikesea
JB weld is a common epoxy sold at local hardwares
bobec
If the magnets are loose could this cause the motor to bogg down at higher speeds?
wilde1j
Can cause worse than that. Make sure the taper and bore are clean and dry before re-installing the flywheel and torque to the correct value.
bobec
Thanks everyone for the info. This was my first post. But probably not my last. Thanks again!!
